I'm looking for a clean black case that has a large clear window. Not too worried about airflow but it needs 240mm rad support. It needs to be atx but still as small as possible. I don't want to go broke, under $200?
Build: Fx-8120@4.1ghz,  Gtx770@1.0ghz,  16gb Patriot memory,  Cheap case from thermaltake
https://linustechtips.com/topic/133732-good-atx-case/
Fractal Design Define R4
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/133732-good-atx-case/#findComment-1779689
Fractal Define R4 or Corsair 450D
Corsair 650D if you have the budget because it is sexy ;)
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
https://linustechtips.com/topic/133732-good-atx-case/#findComment-1779703
