CPU Boost Speeds and Cooling
Go to solution Solved by Chris Pratt,
2 minutes ago, SavageNeo said:
yes. but the stock cooler already does a pretty good job.
I disagree. The Stealth is not a great cooler, and temps will get away from you if you don't have a case with great airflow.
Thermals are just one part of the equation, but yes, generally speaking, lower temps will enable better performance. Get a good single tower cooler, and that should be enough to give you plenty of thermal headroom. You can also undervolt the CPU using the PBO2 curve optimizer, which will give you both extra power and thermal headroom.
So I have been in the market for CPU cooler to replace my stock wraith stealth, and I was wondering about boost speeds. From my limited knowledge with CPUs, I understand that boost clock speeds are achieved through an increase of power consumption, but are limited to the temperature of the CPU. If this is the case, would higher-end cooling theoretically allow the CPU to maintain and achieve higher boost speeds? Thanks. (My CPU is a 5600X, if that helps)
https://linustechtips.com/topic/1337091-cpu-boost-speeds-and-cooling/
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Unless you're changing any settings in bios, stock cooler is pretty fine
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
i never said stock cooler is great. it manages temps fairly well since 5600x dos not eat much power. yes it is loud but it will keep temps in check. if it can keep temps checked with my 3900x, it can certainly do the sam with 5600x
My only experience with the Stealth was with a 3600 and temps reached 90C+ under load in a case that actually had pretty decent airflow and fans. That's not thermal throttling, but it's also not acceptable. If anything, the 5600X runs hotter. Perhaps you're thinking of the Prism? That's a better cooler and is decent enough to actually use, even though it is noisy. The Stealth is just not capable enough.
with me the stealth worked fine? i mean it runs my 3700x around 85C and 3900x around 90C but it wont thermaltrottle much. Well i have undervolted those cpus so it helps. also made a custom curve.
