Budget (including currency): £1500 (GBP)
Country: UK
Games, programs or workloads that it will be used for: r6 siege, warzone, rocket league, old cod games etc. and maybe a little bit of streaming
Ive always wanted to build a pc and now i finally have enough money to for it. I know there are shortages in some parts such as gpus but im looking to build this pc over the next 2 years or so.
Im going to be playing at 4k 144hz and im hoping to get the AMD Ryzen 7 5600x CPU and the RTX 3060 towards the end of my build but for now i have this
Is this a good start and what parts should I be buying now?
Am I overspending/underspending in any areas?
Any tips and comments are greatly appreciated.
https://linustechtips.com/topic/1336893-first-build/
Country: UK
3060ti can not handle 4k 144hz
https://linustechtips.com/topic/1336893-first-build/#findComment-14723725
Change the HDD to 4TB, 1TB won't be enough.
Reduce the SSD to 500gb, install all games in the HDD it should be good.
Change EVGA PSU to Antec Neo Eco Zen.
https://linustechtips.com/topic/1336893-first-build/#findComment-14723730
Don't buy anything now unless you can use it in some way.
F@H
GPD Win 2
https://linustechtips.com/topic/1336893-first-build/#findComment-14723742
