I have a pc and I wanted to build another one and then sell it for fun because I love building pc’s anyway so I built my next pc and the screen didn’t turn on so I put in my 3070 and it worked but when I put my 980 in my other build it worked only when the gtx 980 was I’m my new system it would not work
pc 1 specs
Gpu zotac rtx 3070
Cpu amd 3700x
Mobo gigabyte x570 elite wifi
Ram Corsair 2x8 3200mhz
psu Corsair 650w gold plus full modular
pc 2 specs
Mobo msi h410 pro
Gpu gigabyte gtx 980 wind force
cpu intel core i3 10105f
ram viper 2x4 3000mhz
pzu Corsair 430w 80 plus bronze not modular
https://linustechtips.com/topic/1336725-help-gtx-980/
The problem with “it doesn’t run” it could be any of the components.  Will PC 2 run with the 3070 and a big enough PSU? Any other gpu you have lying around that is known good is another option)  That could tell you if the rest of the system is at least working.
Edited by Bombastinator
https://linustechtips.com/topic/1336725-help-gtx-980/#findComment-14722492
Just now, Markshark36 said:
Pc 2 will run with 3070
Argh. So parts are known good anyway. Maybe a driver issue?  My memory is the 9xx stuff is old enough it may need a different driver.  Also win10 did not play nice with my 970 and my monitor.  It did this weird thing of working and then actually shutting off the monitor.  I think it’s a monitor driver issue with me.  The problem is the monitor is Korean grey-market and I can’t read Korean so negotiating the rabbit warren of the crossover website using Google translate just causes problems.
https://linustechtips.com/topic/1336725-help-gtx-980/#findComment-14722498
  • 3 weeks later...
