Budget (including currency):  ~300
Country:  Ger
Games, programs or workloads that it will be used for: not planning to have heavy stuff done. Some Excel, some little gaming. Just a allrounder and good friend
Hi guys,
as a student i am currently working with a Surface Pro 4 and actually im kinda fine with it even though i cant do much with it. But now i saw this offer and i think this might be a good one. At this point a need a good advice because these two are way to similar 🙂
Offer 1:
CPU: Intel QuadCore CPU i5 6600K, OC @ 4 x 4600 MHz with Cooler: Scythe Mugen4
MB: Asus Z170-P
RAM: 16 GB DDR4
GPU: Sapphire HD 7870! with 2048 MB,
Power adapter: 350 W
Offer 2:
CPU: AMD Ryzen 5 1600 6-Kern CPU, OC @ 6 x 3800 MHz.
MB: ASRock B450M Pro4-F
RAM: 16 GB DDR4 Speiche
GPU: Gainward GTX 680 Phantom with 2048 MB
Power adapter: 600 W
in both offers there is a 256 GB m2 SSD + 1000 GB HDD included
both offers will cost roughly the same ~330€
I looked up some comparisons. The GPU seems to be equal. The Ryzen seems to be better then the i5 on benchmarks - but in the benchmarks i saw they aren't overclocked, so now i dont know... The motherboard are comparable, but B450 is way newer. Pls correct me if im wrong. Right now i dont have any further information, but maybe i can ask the guy offering.
As i wrote, i dont have a need to play games on high settings. Actually i want a good bang for my buck. And maybe if i want to upgrade the components there should be the opportunity in the future.
Thank you very much for any advice!
https://linustechtips.com/topic/1336323-decision-between-those-two-or-none/
The ryzen system is way better.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
All in all good for the price at around 330€? As i looked up the used parts on ebay those bought together would be more expensive than this offer - thats why i am confused
Because there is no real need to buy a system now but in around ~6-12 months.
Thanks for this insanly fast answer!
yeah, its a nice deal (the ryzen system)
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
Country:  Ger
Hi guys,
Offer 1:
MB: Asus Z170-P
RAM: 16 GB DDR4
Offer 2:
The ryzen system is way way better:
The CPU is a 6 core with a single core speed equivalent to an i5-6500 but 6 cores and multi-threading.
The GPU is also good to have considering how expensive are brand new GPUs.Not only that but it's better than the first system.
And the power supply/ power adapter might allow for a newer graphics card to be bought when you ever need one.
IF I were you I would buy it in a heartbeat!It's such a good offer.
