cinebench r23 Cinebench Issues
On 5/9/2021 at 7:03 PM, Captain Kirks Son said:Here are the specs - and no... there is not Overclocking
AMD Ryzen 5 3400G OEM TRAY CPU and Heatsink and FAN
ASUS AM4 MicroATX PRIME B450M-A Motherboard
16GB DDR4 (1x16G) G.Skill 3200Mhz Ripjaws V RAM (x2)
240GB Gigabyte 2.5" SATA 6Gb/s SSD Drive - OS Install
1TB Seagate 3.5" 7200rpm SATA 6Gb/s BarraCuda HDD
2TB Seagate 3.5" 7200rpm SATA 6Gb/s HDD
ASUS RX580 8GB Dual OC PCIe Video Card
Thermaltake MicroATX Versa H17 Window Case Black (No PSU)
Casecom 700W ATX Power Supply
Integrated Sound Card
Integrated Network Card
TP-Link TL-WN881ND Wireless-N 300Mbps PCIe Network Adapter
It's the PSU. If you search online there are numerous reports that that PSU crashes hard when loaded. You have a pretty good system, otherwise, but then you decided to power it with the most bottom of the barrel, cheap, worthless PSU. If anything, the PSU is probably the most important component in your system, as literally everything else depends on clean, reliable, and stable power delivery.
