Hmmm i guess your mic works fine otherwise with other stuff right? (Like voice chat)
Se if you have an option to Enable Streaming in the Recording section on your sound driver/software (like Realtek Sound effect manager) some have that and if then not then im not sure, i did now a way but thast for win XP only you prettu much: Control panel-> Sounds and Audio devices-> Advance-> Options-> Properties-> selected your sound device/Mic-> Recording then enable Sterio Mix, might need to unmute it.
If this ain´t working then im not sure. hopefully someone more knowledgable can help then.
https://linustechtips.com/topic/13362-mic-problem/#findComment-143516
thanks anyway
AMD Athlon 64 x2 3600+ | Asus M2N68-AM SE2 | 3gb ddr2 | Orion 600w | Sapphire HD5570
https://linustechtips.com/topic/13362-mic-problem/#findComment-143567
one more thing! its a cheap mic. you think its the reason?
https://linustechtips.com/topic/13362-mic-problem/#findComment-143570
select listen to device from the sound device properties page.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/13362-mic-problem/#findComment-144082
