Tv Problems
Go to solution Solved by Kilrah,
If your TV only supports 1080p60 then that's all you can use, the xbox won't even let you select something else (and if you could the tv would just not display anything).
Congrats on the series X! It might look a little blurry (if it even works at all), I would use it at 1080p 60hz, or get a new TV at somewhere like Best Buy. You can find 4k TV for around 200-500$ there, I've been meaning to buy one recently lol
Edited by creeperkiller8
correction
https://linustechtips.com/topic/1336003-tv-problems/#findComment-14717287
F@H
GPD Win 2
https://linustechtips.com/topic/1336003-tv-problems/#findComment-14717291
