So Ive got everything built finally in my system. Im running 9 fans all hooked up to the Cpro. I boot up for the first time and all the rgb comes on but fans dont spin. So I shut it off and swapped the CPU cooler fans to the mobo so I can do the install. I did this just to see if I needed the software for the cpro before it would activate the fans. Well I got the software installed and it doesnt even recognize the cpro or any of the fans ( Corsair LL120). Is the Cpro DOA or is therre something im not doing right? Ive got the Cpro ran to the USB header to the mobo and to SATA cable. Ive tried different SATA cables and same thing.
https://linustechtips.com/topic/1335931-issues-with-commander-pro-doa-possible/
Commander pro is a pretty staight foward setup. Show me pics that everything is in order.
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
