HELP PLEASE!
Go to solution Solved by Kilrah,
Moved to troubleshooting. Agreed you should change your title to what your actual problem is.
32 minutes ago, YTjr said:
So I had a previously had a usb with windows 10 but I needed space so I transferred the files to this thumbdrive....unfortunately I don’t know if the files have been corrupted at all. I want to install windows 10.
Just moving the files will not work, you need to make the drive using media creation tool or download the iso and write it to the usb using something like Rufus.
How did you create a USB bootable device? and what exactly are you trying to install? Ubuntu? Windows? Freedos?
https://linustechtips.com/topic/1335256-help-please/#findComment-14711482
https://linustechtips.com/topic/1335256-help-please/#findComment-14711568
In the future please make your thread title something descriptive of your problem. Every day multiple people post threads with titles that are just variations of "help me pls."
It would be better to write a description of your issue in the post, as not everyone viewing this thread will be in a position where they can watch your video, or will even want to.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1335256-help-please/#findComment-14711661
F@H
GPD Win 2
https://linustechtips.com/topic/1335256-help-please/#findComment-14711699
Yeah it's kinda non-intuitive but you can't just put all the files on a USB and have it work. If you don't actually use the Windows install media creation tool, the PC won't know what to do with all those files to actually install Windows.
https://linustechtips.com/topic/1335256-help-please/#findComment-14711753
