Hi guys,
My board is ROG Strix Z370-E Gaming and just 2-3 days ago I had a CPU Fan error which prevents me from booting up.
What I did was, I went to BIOS and just "IGNORED" my CPU Fan instead of it being "MONITORED". Given I don't have anything running through that port as I'm using an AIO cooler connected via CPU Fan Opt, I thought this was the only safe way of booting up.
Anyway, I have 2 questions:
  1. Why did all of a sudden, I had a CPU Fan error? I never had it since and I'm running this rig for about 3-4 years now. - if more info is needed on what are the things that are connected to my PC are, just let me know and I can provide.
  2. Whenever I reboot/restart my rig I have to go back to BIOS and redo what I just did of IGNORING the CPU Fan. - Do I have to do this every single time I turn my PC on moving forward?
I know my rig is kind of old and someone told me that my AIO pump which is Corsair Hydro Series H100i could be bad but I just checked on the iCue and below is what is displayed:
Fan running at 1500rpm on idle
and pump is at 1900rpm on idle with a temp of 36.50c
Do bad pumps detect as CPU Fan error?
TIA
edit: might have posted in the wrong section, if I did, can some mod move this to the appropriate section? Thank you so much.
Edited by Harthelos
https://linustechtips.com/topic/1334953-cpu-fan-error-question/
Yep, this is quite common actually. My Corsair H110i GTX did this about a year back. 🙂
This is sometimes fixable though, a simple disassembly of the block could reveal a clogged pump, which can be easily cleaned.
As seen here:
Early model Corsair AIO's have this issue quite frequently after years of use.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1334953-cpu-fan-error-question/#findComment-14709309
As seen here:
I actually don't have his symptoms though. My temps are clean and never goes above 100 degrees. I think it never climbs up to more than 50-55 degrees Celsius.
I also have no power issues wherein it automatically/randomly shuts down my rig.
I'm so confused as to why I have a CPU error when iCue software says my pump is running okay.
https://linustechtips.com/topic/1334953-cpu-fan-error-question/#findComment-14724234
4 minutes ago, Harthelos said:
Quick question:
  1. Whenever I reboot/restart my rig I have to go back to BIOS and redo what I just did of IGNORING the CPU Fan. - Do I have to do this every single time I turn my PC on moving forward?
No the bios should save the setting.
https://linustechtips.com/topic/1334953-cpu-fan-error-question/#findComment-14732875
