Hi LTT community,
Looking to build (or get it assembled) primarily for Motion Graphics in AE and Adobe suite in general, Light work on Blender, and Capture One. Light gaming, mainly Warframe or FIFA. I've put together a components list that budget and availability would allow.
Components:
-CPU: AMD Ryzen 5 3400G
-Motherboard: MSI B450 PRO CARBON MAX (anything with the upgradeability option up to Zen3 (8c16t), 2 Dedicated GPU (GTX 1660ti or RTX 2060 super?)
-RAM: G.Skill Ripjaws V Series 16GB (2x8GB) 3600MHz
-PSU: Corsair RM750x 80+ Gold
-Storage1: Crucial P5 500GB NAND NVMe M.2
-Storage1: Crucial BX500 1 TB 2.5in SSD
-Case: Lian Li LANCOOL 251
-CPU Cooler: Future upgrade to be quiet! Dark Rock Pro 4
-GPU: I honestly have no idea how to go about this right now. Sign of the times.
Budget (including currency): INR 70,000- INR 80,000
Country: India
Games, programs or workloads that it will be used for: Game - Warframe, FIFA, Rocket League, APEX Legends | Programs - Adobe AfterEffects, Premiere Pro, Photoshop, XD, Blender, Capture One
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): No peripherals needed, although a Monitor recommendation (with good colour representation). No parts bought yet. Possibly by the end of the year, I'd like to build this or something similar.
https://linustechtips.com/topic/1334939-potential-first-build-plan/
4 hours ago, Saha Ashish said:
Hi LTT community,
Components:
Country: India
Gotta be honest here, but with your budget, you would probably have to spend 3/4s of your budget on the gpu alone, with only a little left over, so I hate to break it to you, but unless you want a pc that’s already out of date, you are gonna want to wait
Don’t take everything I say seriously
take it with a grain of s a l t
Exactly what @tirehas said. Unfortunately, unless you are able to get a GPU at MSRP you're not going to be able to build a PC anytime soon. No APU is going to magically give you the performance you're looking for, not even a 3400G.
However, if you're fine with not being able to run anything you have mentioned, then feel free to ask more questions and proceed with the build. That said, I personally find (in my country) that finding a CPU at MSRP is difficult as well, so YMMV.
