No, but it does actually support higher. Intel just doesn't advertise that it does.
You could run a 3200Mhz kit or higher just fine.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1334918-ram-speed/#findComment-14708821
Pretty sure it can run more than that, Intel certifies them up to 2666mhz and K series CPUs can overclock rams when combined with Z series chipset (this changed after this generation).
https://linustechtips.com/topic/1334918-ram-speed/#findComment-14708822
That's just the spec. If you put it in a non-Z series board, that's all it will do at maximum. If you put it in a Z-series board, it will do as fast as all three components (RAM, CPU memory controller, and motherboard) can support, which can vary, but nothing above 2666 is guaranteed. Higher speeds need more tweaking.
DDR 2666 is pretty slow by today's standards. DDR 3200 is almost guaranteed in practice. DDR 3600 is a safe bet. Speeds higher than 4000 take more work and tweaking and are less likely to work easily.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1334918-ram-speed/#findComment-14708825
So would a Z390 work for me?
https://linustechtips.com/topic/1334918-ram-speed/#findComment-14708831
Yes, that's the Z series board that was released for the 9th gen CPUs.
3200 should work with just XMP 99% of the time, 3600 probably also with just XMP (maybe some SA voltage), and 3800+ should work with extra SA and DRAM voltage (probably).
https://linustechtips.com/topic/1334918-ram-speed/#findComment-14708842
I was also wondering how much ram I should get 16 or 32 and if I could buy it used
https://linustechtips.com/topic/1334918-ram-speed/#findComment-14708848
You'll get a couple of different answers:
1. All you need is 16; more memory won't make your games faster.
2. 16 is the minimum and some games can break above that, so get 32.
3. You don't really need more than 16, but if you have 2x8 single rank chips, getting 4x8 single rank chips is like dual rank chips which offers a small performance increase.
I think all of them are right to a degree, but since there's some small benefit from having 32 in a 4x8 configuration, and if you consider 16 is probably enough, saturating all 4 DIMMS won't harm you in the long run for upgrades anyway and RAM itself is a very small expense in the world of $1000 GPUs, I'd get a decent 4x8 kit (which is almost always single rank) or a known dual rank (since not all 16gb DIMMS are dual rank) 2x16 kit.
But be aware that it can sometimes be more difficult to run all DIMMS populated at higher speeds.
My 8700k at 5ghz and 4.7ghz cache manages DDR 3200 easily in 4x8, and my 10900KF managed DDR4 4000 pretty easily at 4x8 as well.
But, it depends, and generally the gains are relatively small unless you're SEVERELY CPU limited and even then only in some scenarios, not all.
https://linustechtips.com/topic/1334918-ram-speed/#findComment-14708869
