Logitech G pro or Razer Viper ultimate?
Fk1
I'm in doubt between the Logitech G pro and the ultimate viper, considering that the pro is at half the price, but I heard some people saying that the pro has numerous double click problems, since the ultimate viper told me that it is immune to double click.
i also had some problems with razer about 4 years ago, however, i was told that the brand has improved a lot in the last few years.
I have both, I like each for different reasons. Have had plenty of logitech mice, some have had double click issues some have not.
Logitech warranty is great for it though. They're very quick and will make sure to turn around a new mouse to you as soon as possible (usually within a week).
If you have any specific questions between the two I'd be happy to answer.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
i have some questions:
- Which is better for warzone (or others fps)?
- I saw some people saying that the ultimate viper sensor is better, is that true?
- is the razer warranty good?
- g pro is at half the price, which one do I choose?
- There's no definitive "better". Depends on your grip, and how you play
- Marginally, but you can't tell the difference
- I haven't had to personally use it, but I've heard it can be a pain in the ass
- Kind of weird as the viper is usually the cheaper one. Being that much cheaper the GPW isnt a bad choice. It's what I'm using right now
my grip is fingertip. What do you think is the best choice?
Same here. Really you can't go wrong with either, get the GPW cause it's cheaper.
G pro X or G pro (in normal version)?
If you can get the superlight absolutely go for it
what changes between superlight and nomal?
Primarily just weight.
I'd say Viper has a better shape. Though if price is such a difference hmm yeah, depends on you and if it's the superlight one too.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
Theyre very similar i would get the viper ultimate if the price differnce isnt massive. The viper is slightly lower profile than the gpw so its better for fingertip.
