Hello, this is my first post here. I want to upgrade from my msi laptop, to something that isn't going to overheat every 5 minutes and will run games at decent framerates. I want to ask for some suggestions and tips. I would like to know id there is something to change about it (for example, am i overpaying, underpaying etc.)
Here is the parts list:
-Case: Corsair iCUE 220T RGB Airflow
-PSU: Corsair RM750x modular
-Motherboard: ASUS ROG STRIX B560-G GAMING WIFI
-CPU: Intel Core i5-11600KF
-CPU Cooler: Noctua NH-U9S
-RAM: Corsair Vengeance RGB PRO 16GB DDR4 3200MHz
-GPU: I am planning on getting a rtx3060, but I'll get the 1050Ti for now
-Storage: 1TB Samsung 970 Evo M.2 SSD
https://linustechtips.com/topic/1333718-building-my-first-pc/
Budget?
Currency or Country?
Preferences?
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700138
3 minutes ago, Luigi04 said:
Just added 2TB of hard-disk-storage because 1TB might not be enough.
Why? Why would someone recommend a Hard Drive in 2021? I do not understand... 🤦‍♂️
And why is that the only thing added? There are a few issues with this build.
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700149
• I would suggest a CX750M or a MWE850 Gold for PSU.
• Get a used 1050 ti ~$200? You have search for them they are pretty rare even at that price.
• You could go for AMD counter part CPU, Ryzen 5 3600x with MSI B550M PRO VDH Wifi.
• Try getting 2x 16gb ram sticks or to keep things under budget 8+8 GB ram sticks because dual channel is better than single channel. Of course 3200Mhz each.
Other stuff is your preference but keep the cooler in the list it's good.
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700162
Here, I just assumed your budget was around $1,000-$1,100 USD, so here ya go 👍
This list ends up costing roughly ~$100 more than yours listed, but is better in almost every way (only similarity is your choice of CPU)
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700169
This is a good selection of parts. To be picky, i would get a 10600K the 1160K is only a small amount better, and im a very cheap person. And a Samsung 970 Evo Plus 250 GB its he is not going to see a difference with a Samsung if primary use is gaming.
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700191
5 minutes ago, kotaq_ said:
Sorry, i didn't ad that, My budget is arround 1300$. Location is Germany, I don't want water cooling, I'm just not comfortable with it. I am also going for aesthetics.
Does that include price of GPU?
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700195
In my area amd cpu's are for some reason quite more expensive. I also forgot to say thet the ram is dual channel.
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700200
• CX750M or a MWE850
PSU's this powerful are not necessary for a mid-tier Gaming PC. Plus, the CX750 is only Bronze efficiency rated.
11 minutes ago, Hofas said:
• used 1050 ti ~$200? You have search for them they are pretty rare even at that price.
Agreed
More expensive, and worse performance
• Try getting 2x 16gb ram sticks. Of course 3200Mhz each.
Why would you recommend either of these for a new gaming build? 32GB's of RAM is not necessary, and 3200Mhz is dumb when 3600Mhz is so similarly priced.
No. That is simply false. Not for a higher-TDP Intel part, no. It has a 90mm fan for christs sake 🤦‍♂️
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700204
8 minutes ago, Wingfan said:
Samsung 970 Evo Plus 250 GB he is not going to see a difference with a Samsung if primary use is gaming.
The NvME I'm recommending as a boot drive/temporary storage rather than straight-up storage for that reason 👍
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700208
11 minutes ago, OfficialTechSpace said:
The NvME I'm recommending as a boot drive rather than straight-up storage for that reason 👍
For his budget, you can tweak that list a little 🙂
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700216
he's in Germany, an american list is completely useless to him.
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700217
Well then all these lists are irrelevant, put PartPicker to Germany
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700219
Yeah I see that now, in case you didn't notice, he hadn't said that until after I made the recommendation
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700225
Case:
The case you chose seems like it should fit everything. Corsair in my opinion makes quality cases. Also, the 220T looks really nice and looks to have great cooling capabilities.
PSU:
If you are going with a 1050ti or a 3060 with an 11600k cpu, then I would recommend saving some money and going with a 600W or so PSU.
Motherboard:
I usually find it unnecessary getting a Strix or similar mobo if you aren't getting a z590, but the mobo you found does seem to be at a good price. However, just keep in mind that you won't be able to overclock your CPU unless you get a z590 mobo. Also, if you haven't done so already, go through all the IO and slots on the mobo and make sure that there are all the ports you may need on this mobo.
CPU:
I'm a big Intel person and I really like the 11600K/KF, which is an impressive core i5 that is meant for gaming. However, at the moment as per PCPartPicker, the best 11600K deal is only $5 more than the best $11600KF and with the UHD 750 iGPU being a great upgrade from the UHD 630 iGPU, I would recommend going with the 11600K and have a more appropriate GPU for internet browsing/ watching videos etc. that uses a lot less power than a 30 series GPU and lets you not torture your GPU by using it all the time.
CPU Cooler:
The one you chose seems like a formidable cooler for a respectable price and I think its difficult to go wrong with Noctua.
RAM:
It's always better to get 2 sticks to have dual-channel memory so I would recommend going with the same thing but splitting the 16gb into 2 8gb sticks. Other than that, the RAM you chose should be enough for your gaming, but if you have the budget and find some good deals then it may be worth getting 3600MHZ and if you really have the budget getting 32gb (2*16gb or 4*8gb) of 3200MHZ memory.
GPU:
Both the 1050ti and especially the 3060 (if you can find one) are good options. Though, if you want superior frames, then it may be worth trying to get your hands on a 3060ti or even a 3070 since both in my opinion are better buys than a 3060 and would pair better with an 11600k cpu.
Storage:
I would recommend getting a 1TB 970 evo plus as opposed to a 1TB 970 evo since it has better specs and is at the moment on sale for about $10 less than the 970 evo on Newegg.
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700233
PCPartPicker Part List
CPU: Intel Core i5-10600KF 4.1 GHz 6-Core Processor  (€185.94 @ Mindfactory) not much worse than the 11600K but you get to save 60-80 euros.
CPU Cooler: Thermalright Le Grand Macho RT 73.6 CFM CPU Cooler  (€76.70 @ Amazon Deutschland)
Motherboard: MSI MPG Z490 GAMING PLUS ATX LGA1200 Motherboard  (€158.90 @ Amazon Deutschland) only Z-series boards can overclock the CPU.
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3000 CL15 Memory  (€83.99 @ Amazon Deutschland)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  (€64.90 @ Amazon Deutschland)
Storage: Toshiba P300 2 TB 3.5" 7200RPM Internal Hard Drive  (€53.53 @ Amazon Deutschland)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  (€69.80 @ Amazon Deutschland)
Power Supply: Fractal Design Ion Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€106.89 @ Alternate)
Total: €800.65
Generated by PCPartPicker 2021-05-02 19:04 CEST+0200
you can try finding a used 290 or something with whatever's left.
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700236
We should be giving advise on building process, installing Win and drivers, etc
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700262
6 minutes ago, kotaq_ said:
I don't think i will have problems with that, maybe the drivers, but all that stuff is easy to find on the internet
Good, because if you cant you will just have a pile of parts. Its relatively easy. When you say aesthetics, do you mean RGB?
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700273
Thread cleaned, please keep it to the build discussion. Normal to have multiple people comment with suggestions and OPs can make sense of them just fine, but when the discussion about too many people giving suggestions amounts to more posts than the suggestions themselves you're not exactly achieving much.
F@H
GPD Win 2
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700313
I saw a CX750 80+ Gold idk
Yea but price was good earlier maybe it's changed now.
I just wanted to mention dual channel, ik 32 makes no sense but upgrades are required after some time.
About 3600mhz, both intel i5-11600kf and ryzen 5 3600x only supports 3200mhz out of the box and idk if motherboard supports 3600mhz xmp
Bruhh I was recommending amd so that cooler is the best for it. Ik intel doesn't need custom cooler.
https://linustechtips.com/topic/1333718-building-my-first-pc/#findComment-14700341
