Hello guys,
first of all, sorry if my english isn't the best.
And this is also my first forum post every, so I am sorry if I did something wrong
I have a problem with my PC.
Everytime when I am starting my PC I get a blue screens after ~2 minutes.
Sometimes I don't get an error code but most likely the bluescreen says "IRQL_NOT_LESS_OR_EQUAL".
I have no clue what is causing this problem and no clue how to figure it out exactly since I am not really good with such things.
If possible explaining things in a easy way would be appreciated.
Please help me, would be really appreciated.
042821-7453-01.dmp
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/
I always get that bluescreen when OCing.
Is your system overclocked?
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14692761
OK, give me a moment to look over the crash file.
More crash files would be helpful, allow me to pinpoint what is happening.
As @Noah0302 said, are you running XMP or OverClocking anything? If so, turn that off.
Test your RAM with MemTest86 as well.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14692773
Ok, I'm going to post the important parts form the crash file, then my thoughts on what may have happened below that
___
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000000000000c8, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
    bit 0 : value 0 = read operation, 1 = write operation
    bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8023a66585c, address which referenced memory
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  x2.exe
___
Ok, the X2.exe file crashed, but that doesn't mean the program is bad, only that it tried to do something invalid. Again, I'd suspect RAM first, so test that. If you have any more crash dumps, please upload them here, it will help establish a pattern.
May also want to ensure your BIOS and drivers are up to date.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14692799
@Radium_Angel
The uploaded .dmp was the lastest but overall there are round about 5 of them.
I never used a kernal debugger, do I have to download it or do it with cmd?
And we tested the RAM with memtest64:
The programm was running for ~5 minutes and nothing happened. (We made a check on "Stop on error")
Do I have to test with Memtest86?
About the X2.exe:
It's a game we are all playing and this never happened before nor to anybody of my mates.
I also updated all drivers if I am not mistaken.
Tried to find some old drivers with a programm to update them manually, I prob. missed some.
Do you have some recommendations to check on updateable driver?
@Noah0302
The PC is not overclocked or anything.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14693629
10 minutes ago, Tw1N said:
@Radium_Angel
About the X2.exe:
@Noah0302
MemTest64 takes a long time to run, especially if you are doing multiple extensive passes.
Depending on the amount of RAM you have installed, and the density of the sticks, it could take HOURS, not minutes....
5 minutes of MemTest64 it way too short.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14693672
Oh, okay.
Thanks for the information.
So I will use Memtest86 then!
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14693676
Please upload all of them, it will help establish a pattern.
You do not need to do anything, I will handle the rest 🙂
Just the website of your motherboard maker, they will have all the drivers you need
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14693777
@Radium_Angel
Sorry for replying that late.
Here are the other .dmp.
Since I have to go now I will do the MemTest86 in the evening and tell you the result.
But I received a new bluescreen which is NOT shown in bluescreenview and had the error: Apc index mismatch
042721-6890-01.dmp 042021-6375-01.dmp 042021-6125-01.dmp
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14697764
OK, first dump:
__
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffad0437b08cb0, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800a5261783, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
PROCESS_NAME:  MsMpEng.exe
SYMBOL_NAME:  dump_wmimmc+1783
MODULE_NAME: dump_wmimmc
IMAGE_NAME:  dump_wmimmc.sys
FAILURE_BUCKET_ID:  AV_R_INVALID_dump_wmimmc!unknown_function
___
CRITICAL_PROCESS_DIED (ef)
        A critical system process died
Arguments:
Arg1: ffff9a0c61aca080, Process object or thread object
Arg2: 0000000000000000, If this is 0, a process died. If this is 1, a thread died.
Arg4: 0000000000000000
PROCESS_NAME:  services.exe
CRITICAL_PROCESS:  services.exe
ERROR_CODE: (NTSTATUS) 0x6915e080 - <Unable to get error code text>
___
Arguments:
Arg1: 000001799c0fb880, memory referenced
Arg4: fffff8055c665656, address which referenced memory
PROCESS_NAME:  nvcontainer.exe
___
None of your crash dumps are repeating, which says to me, bad RAM.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14698542
29 minutes ago, Tw1N said:
@Radium_Angel
So we did the MemTest86 and nothing is wrong with my RAM at least.
I am now trying to check my BIOS and Mainboard if they are up to date.
(Sorry for not responding for a long time)
All good, MemTest said everything is okay? That's...puzzling.
How are your temps of the CPU and GPU?
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14706750
As usual, some relevant info and thoughts below
___
Arguments:
Arg1: ffffaa0000000009, memory referenced
Arg2: 000000000000000d, IRQL
Arg4: fffff8027ac6f9a3, address which referenced memory
___
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: 0000000000000007, Address of the instruction which caused the bugcheck
Arg3: ffff80030134ea60, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
PROCESS_NAME:  csrss.exe
___
The game X2.exe crashed again, but the csrss.exe is more troubling, It kind of points to (BUT NOT ALWAYS!) bad video card, or corrupted video card driver.
I assume you've tried sfc /scannow from a command prompt?
Also, if it's enabled in BIOS (IIRC that's where it is) turn off Fast Boot, that can impact things as well.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14727714
IRQL_NOT_LESS_OR_EQUAL errors are normally due to RAM instability, usually bumping the RAM voltage up takes care of it..... Mind you I said usually, not always.
If you have your RAM clocked up too high, wrong settings and so on, you can get the same error.
To fix:
Make sure your RAM is at stock settings and speeds, also be sure RAM voltage is correct, either at stock or even a tad over their stock voltage  - Won't hurt a thing to set it manually to do that.
Do all that and test.
It's also possible to have a stick going bad, causing this error to appear.
You can check that with a run of Prime 95 or other RAM testing bench/util.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14727818
To fix:
About the the PC:
It came back from the Company, it's prebuild from a german Website.
We had to send the PC to them once since the PC was not able to find a Source and iirc they replaced the RAM.
So I am really confused why this happens.
The PC was bought in September and the problems happened ~1-2 Month after buying and using.
The RAM and everything is NOT clocked or anything.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14732418
___
Arguments:
___
Arguments:
___
We just recently Updated the driver of her GPU.
Yes, we tried the scannow and nothing Was wrong there
I just disabled the "Fast boot" in the BIOS.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14732424
Ok, let us know if anything improves or not.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14732435
I think I got it.
And I feel really sorry for your time.
It was the driver of my BIOS probably.
I updated the driver yesterday and today there was no Bluescreen.
I will keep looking if I get some in the next days but it seems like this was the problem.
I am sorry.
https://linustechtips.com/topic/1332675-irql_not_less_or_equal/#findComment-14738105
