Just now, BasicallyAMod said:
so all the cooling is outside and not warming my house
What are you going to do when the hot air of the outside actually heats you components up?
https://linustechtips.com/topic/1331657-crazy-cooling-idea/#findComment-14685319
1 minute ago, BasicallyAMod said:
its always going to be less that 50c outside, and components get hotter than that
am i dumb?
Yes, even under heavy load, the fluid temperature rarely exceeds 40-45 degrees for an average loop (conservatively), and that would be with an ambient temperature in the 20's. So if the ambient temperature is in the 40's, so will the fluid temperature, and then the component temperatures will be significantly higher. If your indoor temperature is lower than the outside temperature, then it doesn't make sense to use the outdoor heat to "cool" the PC.
https://linustechtips.com/topic/1331657-crazy-cooling-idea/#findComment-14685365
ok that makes sense. Thanks
https://linustechtips.com/topic/1331657-crazy-cooling-idea/#findComment-14685369
Get a real fan and shroud. Not some box fan.
https://linustechtips.com/topic/1331657-crazy-cooling-idea/#findComment-14686089
