Arctis 3 split audio issue
Go to solution Solved by Kanna,
okay so I did some more research and found what it did it is called "share jack" it makes you able to share the sound to another headset
I'm using my headphones with the cable plugged into the PC and a 3.5mm plugged into my phone but the sound is split between the ears for some reason and the one ear there is this like radio bad connection sound
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1330944-arctis-3-split-audio-issue/
Just now, jaslion said:
You aren't supposed to connect them to 2 audio outputs at the same time.
I'm not? what's the port for then?
Reminder⚠️
But you are connected to the pc and phone at the same time right?
You are only supposed to have one input active at a time on the arctis. Either the steelseries cable or a 3.5mm jack. NOT both at the same time either plugged into the headset and then to nothing or plugged into the headset and connected to something.
but the same issue is occurring when I only use the 3.5mm cable into my phone (even tried PC)
Reminder⚠️
Reminder⚠️
