My cpu went crazy
Go to solution Solved by Heliian,
Why did you turn the fan off?
Make sure everything is plugged in and turn it on.  Should be back to normal with a fan on it.
Ok so I was cleaning my pc and I had turned off the cpu fan but forgot to turn it on later when I turned on the pc and after few minutes I realized it was at like 100C. I turned off the pc, turned on the fan and waited like 20 min for the cpu to cool down but when u turned it on it still was at like 100C. How long do I have to wait for the cpu to cool down and is there a way to cool it down my self faster.
https://linustechtips.com/topic/1330838-my-cpu-went-crazy/
what do you use to measure thermals? If the fan is on it should not be at 100C even if the cpu cooler is not properly mounted.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1330838-my-cpu-went-crazy/#findComment-14679261
