<-- Moved to New Builds and Planning -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1330797-help/#findComment-14678902
I say for something like mouse or keyboard or even mouse pad and headphones "locally" since that was much cheaper
Also you have 2 mices and cooler there
And lastly you maybe want to use a pcie/ mini-pcie wifi card one instead of those usb one... In my experience the pcie/mini pcie are having lower latency albeit around 10-25ms though it has Bigger antenna and that's mark my other points of pcie wifi card, you can buy the high gain antenna in the future;)
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
https://linustechtips.com/topic/1330797-help/#findComment-14678946
It is not 2 mice it is 1 mouce and grip tape
https://linustechtips.com/topic/1330797-help/#findComment-14679007
There are a number of difficulties with the list contents. Principal among these is the lack of a discrete gpu. For a gaming system this is a problem. The igpu that is part of the cpu is fine for general productivity, streaming media, etc. it is not powerful enough for intensely graphical games and applications like video editing.
The cpu is unlocked and really should use a Z590 motherboard. The B460 would be better used with an i9-10900 or i9-11900.
Neither of the two cpu coolers are suitable.
The psu is not appropriate.
New cpu coolers come with a tube or pre-applied pad of thermal compound. There is generally no need to purchase more.
With an MSI motherboard you should make sure that components with lighting are compatible with Mystic Light, the motherboard's lighting control system. This will allow syncing of all lighting.
The list below uses US prices. You will have to check local availability and pricing. The list does not include peripherals as they are personal preference.
PCPartPicker Part List
CPU: Intel Core i7-11700 2.5 GHz 8-Core Processor  ($339.99 @ Amazon)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler  ($69.94 @ Amazon)
Motherboard: Asus TUF GAMING B560M-PLUS WIFI Micro ATX LGA1200 Motherboard  ($165.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL15 Memory  ($229.99 @ Newegg)
Storage: Samsung 980 Pro 2 TB M.2-2280 NVME Solid State Drive  ($349.99 @ B&H)
Storage: Samsung 860 Evo 4 TB 2.5" Solid State Drive  ($399.99 @ B&H)
Case: Fractal Design Define 7 ATX Mid Tower Case  ($169.99 @ B&H)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($107.39 @ Amazon)
Optical Drive: Pioneer BDR-211UBK Blu-Ray/DVD/CD Writer  ($189.99 @ Amazon)
Total: $2023.26
Generated by PCPartPicker 2021-04-23 20:19 EDT-0400
https://linustechtips.com/topic/1330797-help/#findComment-14679187
Total: $2023.26
like all the parts to make a good pc but i need a really big case so i can edit it later if i need to... btw i need 4tb and 64 gb ram.
https://linustechtips.com/topic/1330797-help/#findComment-14679211
1 hour ago, OanMX_GT said:
I have a question...
shouldn't a i9 core fit and be faster?
And the case is too expensive.. do you think this will work???
or this
The I9 is terrible.I wouldn't buy it.In some rare cases it's actually worse than the 10900k.
https://linustechtips.com/topic/1330797-help/#findComment-14681297
An i9-11900 would be fine. If you want the i9-11900K, change to a Z590 motherboard.
You had said that you wanted a bigger case. The motherboard will fit in any ATX case including the two you asked about. The NH-U12A will also fit in either case. Keep in mind the lighting control if you want to sync it all.
Also, neither of those cases has a front panel usb-c port. The motherboard I suggested does. If you don't care about the feature either case is fine. If you do, consider something like https://www.amazon.ae/be-quiet-BGW37-BE-Quiet/dp/B087D7DBW6/ref=sr_1_1?crid=HVGZ4HJ27EA5&dchild=1&keywords=pure%2Bbase%2B500dx&qid=1619369523&sprefix=Pure%2Bbase%2Caps%2C299&sr=8-1&th=1, good airflow and ARGB front and interior lighting or https://www.amazon.ae/Phanteks-PH-EC500ATG_DBK01-full-metal-Mid-tower-Digital-RGB/dp/B088T3VMKK/ref=pd_sbs_4?pd_rd_w=3JwiN&pf_rd_p=a7135f3f-28e2-4668-a4f0-afeb9c1fc3a4&pf_rd_r=V5SN1X8YH7PKDX71XXJS&pd_rd_r=0956b00c-ed27-47c1-b670-7dc58a026b69&pd_rd_wg=XDIs8&pd_rd_i=B088T3VMKK&psc=1 also good airflow and ARGB fans.
https://linustechtips.com/topic/1330797-help/#findComment-14681870
