I'm looking at getting a new camera but not really sure what I'm look for. i want a camera that is got for action shots with a good burst mode that i can also use for just general photography. advice on lenses would also help as i haven't a clue when it comes to lenses. looking at spend around £1500 - £1800 for the time being.
https://linustechtips.com/topic/1330485-camera-advice/
<-- Moved to Photography and Videography -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1330485-camera-advice/#findComment-14676374
The best camera for your needs, is the one that feels great in your hands.
If it's uncomfortable or awkward to use, then you will be less inclined to use it (source: I am a professional photographer)
So, go play with a bunch of cameras at your local shop, see how you like the most. That will be the one that is best for you.
As to the lenses, a beginner won't be able to take advantage of expensive lenses. Get yourself a 50mm f/1.8 lens. Very very flexible. They don't call it the "nifty fifty" for nothin.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1330485-camera-advice/#findComment-14676378
I also agree with what @Radium_Angel said about how it feels like your hand. You may not care as much if the camera hangs around your neck or sits on a tripod for most of the time.
My suggestion for a body would be something like a Canon 77D or Nikon D7200 or similar. For lenses, the 50mm or some 'normal zoom' lens.
If you're going to end up continuing with photography, the general consensus is to invest in glass(lenses), but that also means you're typically stuck to that brand/ecosystem unless you feel like selling and rebuying.
Read before asking for help  |  How to respond to a no POST or no power up situation  |  Don't ask to ask, just ask  |  The XY Problem  | Don't just say "Hello" in chat  |  How do I ask a good question?
If my post helped, please give a 'reaction' using the heart 🤍 in the bottom right.
Make sure to quote posts or tag the person with @[username] so they know you responded to them!
F@H Contribution
BOINC Contribution
HeatWare
"The only difference between a problem and a solution is that people understand the solution."
"Give people permission to make mistakes and the obligation to learn from them."
“The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.” - Brian Herbert
"People will never truly understand something until it happens to them."
"I usually give people more chances than they deserve but once I'm done, I'm done."
CPU AMD Ryzen 7 3700X  |  Motherboard Gigabyte X570 Gaming X  |  RAM Corsair Vengeance LPX 2x8GB 3600MHz  |  GPU ZOTAC GAMING GeForce RTX 3070 Ti Trinity OC |  Case BitFenix Ghost  |  Storage HP EX920 1TB, Samsung 840 EVO 250GB, WD Black 8TB, Seagate Barracuda 4TB  |  PSU Seasonic Prime GX-750  |  Displays Lenovo ThinkVision P27q-20, Dell UP2716D  |  Cooling Noctua NH-D15  |  Operating System Windows 10 Home
https://linustechtips.com/topic/1330485-camera-advice/#findComment-14677012
  • 4 weeks later...
You could consider getting a second hand camera. From sites like mpb.com
I would recommend the Canon 5D Mark IV
https://linustechtips.com/topic/1330485-camera-advice/#findComment-14739202
5dkm4 is the last body I'd start with in 2021
for action stuff you want a higher end crop body
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1330485-camera-advice/#findComment-14739317
