Do I have problems with my GPU or CPU?
Ok, so I recently bought a game called Squad, it was going all good, until it started crashing a lot. I checked out with other people, and they told me that the game doesn't crash, and is going 60fps on their CPUs and GPUs, which were even worse than mine. I have an AMD Ryzen 5 1500X with 4 cores and 8 threads 3.5GHz. The GPU I'm using is and Nvidia GeForce GTX1050ti with 4gb of vram. I've got 16GB of ram, and a HDD with 1TB of space. I play on lowest possible graphics, and on 1080p resolution with 75% resolutiong scale. While playing I was watching graphs on the task manager, and i saw that i got around 30-50 % of usage of CPU with around 80-90 °C temperature, and around 70% usage of GPU on 70 °C.
I got this PC in 2016 or 2017, and never had any big problems with it. I guess the biggest problem is CPU overheating? I am not sure about that, i never changed the thermal paste, so I guess that is the problem. Im gonna need someone to help me, and tell me if I did guess right or not.
Thanks in advance 🙂
https://linustechtips.com/topic/1330421-do-i-have-problems-with-my-gpu-or-cpu/
What monitoring apps did you use for this? Ryzen Master or something else?
But anyway, when does it immediately crash? During loading up a game or during in game?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
6 minutes ago, I5LQ said:
Hey can you send a picture of your gpu so i can know if its fake or not because that happend to me when i bought a gtx 1050ti and its fake it will crash you from lots of games the fake one has a VGA por the real one dont check that please ^^
That should not be the case, because i bought it from an official store.
I used Ryzen Master, and it crashes instantly on some bigger maps and servers with more people, and on others, it crashes while i am in a match.
Possibly either asset missing or driver instability. Reinstall your graphics driver and verify your game files. And thats pretty toasty CPU too.
Could you attach a picture
scam cards make their way onto reputable retailers (Newegg Ebay amazon ETC) all the time.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
Try 720p and check if it will crash there. Seen a lot of crashes thx to full VRAM and with 4GBs you are at the limit for 1080p.
Edit: i jsut now saw you have 90°C on the CPU. This isn't right. Take out the cooler clean it and apply new thermal paste. As a whole this system looks to be running really hot (GPU should also be in the low 60s, not 70s). Clean out the whole system.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
