Hello everyone!
I'm looking for a vertical GPU mount kit for my Corsair 680X and ROG STRIX 3090 that requires a maximum of 6 open PCI slots.
I already got my eyes on the Phantek "VERTICAL GPU KIT" but it needs 7 open PCI slots and I only have 6 slots free, because of a USB extension card.
Does anyone know of a vertical GPU mount kit that only requires 6 or even less open PCI slots? (preferably 5 PCI slots)
Thanks 🙂
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1330368-looking-for-a-vertical-gpu-mount-kit/
Just now, LogicalDrm said:
-> Moved to Cases and Mods
Sorry, and thank you 😊
GAMER
Home LAB
Racing SIM
6 hours ago, BetteBalterZen said:
Hello everyone!
Thanks 🙂
you want to mount 7 vertical cards?
No? 😊
GAMER
Home LAB
Racing SIM
8 hours ago, BetteBalterZen said:
Hello everyone!
Thanks 🙂
heres a PCI 4.0 one
https://www.amazon.com/Phanteks-PH-VGPUKT_02-Universal-Vertical-Pci/dp/B07MW73HTJ/ref=sr_1_8?crid=2UN68YILHDOBN&dchild=1&keywords=vertical+gpu+mount+pcie+4.0&qid=1619192244&sprefix=vertical+gpu+mount+pci+e+%2Caps%2C194&sr=8-8
KanyeWestLover911
Reminder
I'm just speaking from experience so what I say may not work 100%
I Use Arch BTW
my PCs
these are my Pcs
https://pcpartpicker.com/user/mtj08/saved/
6 minutes ago, POG Gamer said:
It uses too many slots though. If it uses 7 or more slots it will hit my USB-extensioncard.
GAMER
Home LAB
Racing SIM
it only take 5
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
1 minute ago, POG Gamer said:
i guess 6 for the bottom area
Yeah it's kinda hard to see. I've seen a reviever say it actually takes up aroud 7 slots, lets say 6,5 slot and that won't work unfortunately 😜
GAMER
Home LAB
Racing SIM
oh ok
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
i know some other but they are only PCI E 3.0
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
That is fine. I should not use a 4.0 riser with a 3.0 motherboard anyway.
Please link the ones you know of 😀
GAMER
Home LAB
Racing SIM
https://www.amazon.com/EZDIY-FAB-Vertical-Graphics-Bracket-Multi-Angle/dp/B08R9P5G8V/ref=sr_1_6?dchild=1&keywords=VERTICAL+GPU+KIT&qid=1619214456&sr=8-6
KanyeWestLover911
Reminder
I Use Arch BTW
my PCs
these are my Pcs
vertical gpu mount's are bad for air cooled gpus just so you no. i thought it was the bees nees but an video shed some light on how air flow works to the gpu. its more or less for water cooled gpus.
