Hi, so I have a 2060 Super, I haven't played any game in 2 weeks and when I came back I started experiencing low frames for example on forkknife I used to get 140+ frames now I'm getting between 80 to 90 frames. I tried removing and reinstalling the drivers using DDU and then I also tried going back to the older drivers, both of those attempts didn't work. I hope someone finds out what could be causing this problem.
Specs:
- Ryzen 7 3800X
- RTX 2060 SUPER
- TUF B450M PLUS GAMING MOBO
- 16gb DDR4 [ 2 x 8 ] 3200mhz HyperX Fury RGB Memory
https://linustechtips.com/topic/1329959-stuttering-and-low-frames-help/
What's the rest of the build? Have you tried monitoring CPU and GPU usage and temperature while gaming?
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
Is CPU and Memory usage normal?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
