Samsung G5 Odyssey VS MSI Optix G27CQ4 ??
Hello I am looking to buy a 27" 144HZ curved monitor with 2K resolution to replace my 24" dell 1080p 60 HZ monitor.
I couldn't find an IPS monitor where I live which fits my budget so I guess I'm going with a VA panel which from my understanding is not that bad.
I was going to go with the Samsung G5 Odyssey but some reviews said that it had a bad build quality, my second option was the MSI Optix G27CQ4 which according to reviews had some ghosting and blur problems. As for the AOC monitor it was recommended by the dude in the store but I have no idea whether it's good or bad but its cheaper than the others (not by much).
Any idea which one is better or if there is an even better option in the same price range
1- MSI 27 inch Optix G27CQ4 2K 165hz Curved
2- AOC CQ27G2 27" VA 2K 144HZ
3- SAMSUNG 27-Inch G5 Odyssey Gaming
Thank you so much in advance,
