Power supply making buzzing noise
Solved by virxually,
2 hours ago, KingTdiGGiTTy said:try stopping the fan
don't get electrocuted.
Are you still under warranty? RMA could be an option.
I may have found the problem..
Its not the power supply at all, its the filter underneath the power supply.
Whenever the buzzing noise starts, I slightly pull out the filter and it stops immediately. Im guessing what happens is when the fan hits high rpm it starts rattling the filter slightly causing a buzzing noise against the case.
Found someone having the same issue on another case:
My case is a Corsair 4000X
