Budget (including currency): $1k USD
Country: United States
Games, programs or workloads that it will be used for: streaming while gaming, GTAV, Minecraft, CSGO.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): first build, need help. I wanna do 60 fps 1080p gaming. I want a well cooled system that is overclockable. I’d prefer ryzen but you can do intel.
https://linustechtips.com/topic/1329216-best-1k-build/
Here is your pc parts list
Amd ryzen 5 3600 (241$)
Corsair vengeance LPX 3200mhz (2x8).   (124$)
As rock B450 steel legend (119$)
Antec A40 pro cooler (26$)
Ant eSports ICE 511 MT mid tower case      ($60)
WD blue 1 tb hdd ($41). Crucial balisticks 500 gb sata SSD(42$)
Antec HCG 850 bronze 80+ ($120)
 All of the parts I have picked from Amazon and I don't konw about the GPU because if the current situation .
For GPU I think so  that nividea Quadro will work for gaming  but don't know about streaming. If there are any mistakes pls rectifie them .
https://linustechtips.com/topic/1329216-best-1k-build/#findComment-14667032
Ur funny. A Quadro is like 10 grand
https://linustechtips.com/topic/1329216-best-1k-build/#findComment-14667134
The other parts are pretty good tho
https://linustechtips.com/topic/1329216-best-1k-build/#findComment-14667137
Edit: I understand that there are different names of the quadro
https://linustechtips.com/topic/1329216-best-1k-build/#findComment-14667142
