Hi all,
I have been trying to get my head around this with online articles etc and would appreciate some help. I am trying to setup wake on LAN for my home PC. The reason for this is so I can use Parsec, and utilise my powerful PC at home for gaming/heavier workloads whilst I am anywhere with a decent internet connection. Current setup is:
Linksys Velop router -> Huawei AX3 router -> PC.
I have setup wake on lan in the bios, and in windows. I have setup port forwarding on the Linksys router, but am getting lost with how to tie this up to the 2nd router and which IP's need to go where.
I think it is: external IP for the Linksys velop and choose a port. Then setup a rule for that Velop router to forward from that IP/port to the internal IP of the Huawei router and select another port? Then on the Huawei router, I can select the specific internal IP for the PC and choose a port?
Then I am using WOL or Teamviewer to try and wake it.
Any corrections/advice would be greatly appreciated.
Thank you
Mark
https://linustechtips.com/topic/1329091-help-setting-up-wake-on-lan/
