hi i have a issue, i recently got a rx570 and im currently testing it and most if not all games im testing 60fps or above but its as if the monitor is stuck at 30 fps as it doesnt look very much like the 60+fps even on just plain windows like the animations for open the start menu etc are not smooth like 60hz, it says it is, the monitor is set 59.4hz or something like that, any idea why it looks like its stuck to 30? with my old nvida gpu it was fine, i ran ddu so theres no nvida drivers left
https://linustechtips.com/topic/1327652-i-need-help/
Just now, WaddlesTM said:
idk how monitors work.
you need to stop jumping to conclusions and troubleshoot things. If you don't know how to help don't comment!
I've seen you post another post like this "REPLREPLACE YOUR FANS!"
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1327652-i-need-help/#findComment-14654834
After removing the Nvidia drivers you did install AMD ones, right?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1327652-i-need-help/#findComment-14654850
Just now, Toddthe... said:
should i try another monitor and or cable?
You can, but I doubt it's the issue.
SPECS:
https://linustechtips.com/topic/1327652-i-need-help/#findComment-14654902
