Pc help
42 minutes ago, ANME-Milim said:With the whole gpu marketplace being as it is im rllllly wanting to get a pc
I want to get one now and then upgrade budget is $1200 AUD rn then ill upgrade later
I have chosen to get a b450 tomahawk max with 2x8 3200mhz ram, 1tb m.2, 750w, ryzen 5 3600
since i wanna get it asap do i get a 2200g with integrated graphics ($169 AUD) instead or do i wait and if so how long approx will i hav to wait for a gpu
Games i wanna play are minecraft mods, terraria mods, league, destiny 2, rust
I get the apu wont run rust and destiny 2 but is it a good idea to just get the apu or is there a better option?
You could go for Intel, and wait out these terrible times with an iGPU, yes the iGPU woudn't be as good as a Vega GPU... but that would save you from buying a CPU now, selling it probably and buying the 3600 later. You could look into these CPU's -> 10400, 11400 or even an 11500 with appropriate mobo and ram ofc...
