Budget (including currency): 100,000 PHP
Country: Philippines
Games, programs or workloads that it will be used for: Streaming, Gaming, Editing
Processor : Ryzen 7 3700x (I can't decide on whether to get the 5600x and I need your guys help on that)
Cooler : Stock | or something liquid cooling from corsair or nzxt
MB: B550 Vision D - P (i don't know whether this is already fine or 3000s ready)
RAM: 32gb (dual) ddr4 3200 G.Skill Trident Z Neo, Ryzen, CL16
Storage: 500GB M.2 SSD & my laptop 2.5inchssd and m.2
GPU: RTX 3070 Vision OC
Case: Thermaltake Core P3 [wall mounted] white
PSU: Corsair PSU, CX, CX650F RGB, white, 80 bronze, full modular
I need your guys help, I'm open to criticism and if I need to change something for compatibility please tell me. Thanks 🙂
https://linustechtips.com/topic/1327501-i-need-help-on-compatibility-n-stuff/
everything is compatible and as for the 3700x vs 5600x I would personally go with the 5600x, if you're main task is gaming. Your board will be ryzen 5000 ready with a bios update, there should be a button on the IO panel of the motherboard, you can watch a youtube guide on how to update the bios with a usb drive and the flash button if you need help.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
B550 works out of the box with 3000 series, except for those with a G, which are not supported at all. You're fine. For 5000-series, you'll need to update the BIOS first, but it'll work fine. If you were just gaming, I'd say get the 5600X, but for productivity, you'd be better served sacrificing a little single core performance for the extra two cores with the 3700X. If you want the best of both worlds, spring for the 5800X.
Stock cooler is okay, but you're going to want something better sooner rather than later. AIO is unnecessary, though. You'd do just fine with a good single tower cooler like a Noctua U12S. If you want to go really overboard, you can get a D15, and actually exceed the cooling of all but a 360mm AIO.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
