Budget (including currency): 500/600 Euro
Country: Germany
Owned
Storage - 1TB Seagate Desktop HDD - New
1TB Samsung 860 Pro SSD - New
Graphics - EVGA GeForce GTX 980 Ti 6 GB Superclocked+ ACX 2.0+ Video Card - New
Intend to purchase:
Case - €69.99
We're currently looking at an 'Empire Gaming - Diamond' Case, it comes with 4 built in fans with addressable RGB. Mid-sized ATX / Micro ATX / Mini ITX compatible.
Looking for suggestions
Motherboard - Would be nice if it had wifi, but would rather just buy a cheaper WiFi dongle and spend the money elsewhere. Will be connecting to ethernet whilst gaming online anyway.
CPU - Really don't know which way to go. I have no preference for team red or team blue. Happy to go with second hand but at this point I just want to get the thing built so I'd rather 'BuyItNow'.
CPU Cooler - Something that fits
RAM - I'd like to go for 16GB or up. If my budget doesn't allow then I'll settle for 8 and just buy another stick in a month or 2.
Power Supply - Not too fussed about power efficiency. Will just chuck everything into PcPartPicker and go for a Voltage beyond what it estimates.
https://linustechtips.com/topic/1327202-help-please-need-to-make-decisions/
6 minutes ago, maxdachamp said:
Looks like a Lian Li Lancool 2 Mesh Ripoff, so i would go for that instead. Other recommendation at that price range is 275R Airflow by Corsair, or Focus G by Fractal Design.
Well that automatically going to make you go Intel in this case, but if AMD CPUs are available, go for the Zen 2 CPU (Ryzen 3xxx series) or the Zen 3 (Ryzen 5xxx series) with a B550 Board. A lot of them is going to have Wifi 6 equipped out of the box. For Intel side, go for an i5 10400F with any reputable B460. Pretty much the bang for the buck set for the LGA 1200 platform.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
