Hello!
I'm in the planning process of building a Razer oriented PC and would welcome some feedback. This is not going to be a budget PC by any means. My main concern is, with all the parts I've researched and am considering, would I have any serious problems down the line? Or maybe if there are better alternatives that I haven't found that would go great with this build instead. I've also been considering waiting for AM5/DDR5/PCIe5.0 to come out as well.
So far I've only got the case, the other components I'm willing to tweak if there's a solid enough reason.
Case: Razer Tomahawk Mid-ATX Tower
Motherboard: ASRock Taichi X570 Razer Edition
CPU: AMD Ryzen 9 5900X
GPU: EVGA FTW 3080 (Maybe 3080ti when it's available)
RAM: G.Skill Trident Z DDR4-3600MHz (32gb 2x16gb)
PSU: EVGA P2 1200W 80+ Platinum
CPU cooler: NZXT Kraken Z73 AIO
Storage: Samsung 980 Pro M.2
https://linustechtips.com/topic/1326232-razer-build/
Just now, boggy77 said:
what are you using this build for? some of the components seem very overkill and overpriced, like the PSU, cooler and ssd.
if mostly gaming, you also don't need a 5900x, a 5600x or 5800x are enough.
It's going to be for gaming, video editing, and streaming. There's also the potential for some creative works as well but I haven't gotten that far yet. I'm okay with overkill and overprice so long as I don't run into any serious bottlenecks or compatibility issues in the future.
https://linustechtips.com/topic/1326232-razer-build/#findComment-14644379
it's fine then, no bottlenecks there.
https://linustechtips.com/topic/1326232-razer-build/#findComment-14644383
2 minutes ago, Hyrogenes said:
Pcie 5.0 isnt coming out for a while. DDR5 still wont hugely give a performance boost as most cpus don't benefit from most high end ddr4 speeds much less ddr5
That's a fair point as well. I just didn't know if anyone had any further insight on that upcoming generation, given the current shortages going on now.
https://linustechtips.com/topic/1326232-razer-build/#findComment-14644397
From what we know so far next gen cpus will possibly have ddr5 support and 2 generations from now will almost definately have it. Pcie gen 5 is anywhere from 2-10 generations away. Its hard to predict
https://linustechtips.com/topic/1326232-razer-build/#findComment-14644400
4 minutes ago, boggy77 said:
just keep in mind you need a gpu for the pc to run, as the 5900x doesn't have an integrated gpu. so you can't really build and use your pc until you manage to get a gpu
Yea that's been my biggest drawback and also part of the reason I haven't ordered any of the parts yet. I'm hoping to maybe get in to the verified gamer program but I've also considered the fact I may have to fork over for the 3080, or possibly go with something lesser until the market normalizes again.
https://linustechtips.com/topic/1326232-razer-build/#findComment-14644401
