help Graphics Not Running But Integrated Is? Please Help!
Solved by bellabichon,
Open the Nvidia Control Panel (should be an option when you right click anywhere on the desktop), go to Manage 3D Settings, and change your preferred graphics processor to "High-performance NVIDIA Processor". Alternatively, you could also select which GPU to use on a per-program basis (i.e. if you wanted Google Chrome to use the iGPU to save battery life).
