Budget (including currency): $1500 USD ($1000 USD without GPU)
Country: USA
Games, programs or workloads that it will be used for: I want a pc for gaming with the eventual goal of streaming. I have created a list of parts I am considering getting (see below). I am not going to buy a graphics card until I can get one for MSRP, so I am waiting for now. I play league, TFT, Among Us, and Chess, so waiting isn't a huge deal. I would like to have a nice NVIDIA GPU eventually because I want to stream on Twitch.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Here is the PC Parts Picker List I created. I am going with a brown and white theme because I am going to add some stickers of the BT21 character Shooky. I just wanted to get a second opinion on what I have picked out :) Thanks in advance!
PCPartPicker Part List: https://pcpartpicker.com/list/97w9ZZ
CPU: Intel Core i5-11600K 3.9 GHz 6-Core Processor  ($264.99 @ Adorama)
CPU Cooler: Noctua NH-L9i 33.84 CFM CPU Cooler  ($44.95 @ Amazon)
Motherboard: Asus TUF Gaming Z590-PLUS WIFI ATX LGA1200 Motherboard  ($254.79 @ Amazon)
Memory: Crucial Ballistix RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($99.95 @ Amazon)
Storage: Samsung 970 Evo Plus 500 GB M.2-2280 NVME Solid State Drive  ($79.99 @ Adorama)
Storage: Seagate Barracuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($46.22 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: EVGA 600 W 80+ Certified ATX Power Supply  ($39.99 @ Best Buy)
Case Fan: Noctua F12 PWM 54.97 CFM 120 mm Fan  ($19.95 @ Amazon) x 4
Total: $1005.67
Generated by PCPartPicker 2021-04-12 14:46 EDT-0400
Get a different cooler. Something like the Arctic Freezer 34 esports duo will cool much better than that.
The motherboard is a bit too much for the chip you're using.
If you're waiting for the 3070 or something like that to reach $500, then you'll want a higher wattage PSU. The last thing you want to cheap out on is the PSU, so use some saved motherboard money on a better PSU.
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
This cooler is rated for a maximum of 65W TDP. The CPU you chose has a 125W TDP
A 2TB hard drive is not much more than the 1TB you chose https://pcpartpicker.com/product/mwrYcf/seagate-barracuda-computer-2-tb-35-7200rpm-internal-hard-drive-st2000dm008
Motherboard is too expensive and power supply is too weak.
I would go with either an 11400 or a 5600x, a 11600k does not really make sense.
I actually was hoping to get a 1660 super, 2060 or 3060. I would be happy to be under budget. Do you still recommend a higher wattage PSU?
Oh right, well yeah I would still recommend splurging a little on the PSU. It will give you peace of mind that your PSU is good enough if you decide to upgrade in the future.
I updated the part list from everyone’s recommendations. I’m trying to limit it to what’s in stock at Amazon and Best Buy, with a preference for Best Buy (I can pick up items fastest). Does it look more reasonable?
PCPartPicker Part List: https://pcpartpicker.com/list/wfC3QD
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor  ($183.99 @ Amazon)
CPU Cooler: Noctua NH-U9S 46.44 CFM CPU Cooler  ($54.99 @ Amazon)
Motherboard: MSI Z590-A PRO ATX LGA1200 Motherboard  ($189.99 @ Best Buy)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($109.99 @ Amazon)
Storage: Samsung 970 Evo Plus 500 GB M.2-2280 NVME Solid State Drive  ($89.99 @ Best Buy)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($55.49 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Best Buy)
Total: $984.22
Generated by PCPartPicker 2021-04-12 15:49 EDT-0400
Total: $984.22
Question: Why does he/she need a z590 board with a non-overclockable CPU? They should get a b560 board, and divert sine funds to a video card or to a power supply, potentially even more storage.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
I don’t like the aesthetics of the micro-ATX motherboard in the mid-tower case. I chose the most affordable full ATX motherboard available at those retailers with an aesthetic I didn’t find too manly (I’m a female and this is going in my very cutesy setup). Does that logic make sense? I’m very new to this.
Here, lemme make u a pcp list with my thoughts. Does your budget include a monitor, keyboard, etc?
Gaming PC:
I have all the peripherals. I used to dock a laptop to my setup. I just need the tower.
 How's this? (850 watts is to let you upgrade to a viable video card in the future
Gaming PC:
17 minutes ago, FireAbyss111802 said:
Is there a functional difference between the cooler and motherboard you chose and what I chose? It seems like they’re just different brands but otherwise similar to me. Also, I had case fans included in my build. Do you think they’re unnecessary?
Thank you so much for taking the time to help, by the way 🙂
So, your cooler is meant for low-profile builds (mini itx) and therefore, have less cooling potential. I would suggest getting the Dark rock 4 so you have some sort of an upgrade path  with your CPU. Motherboards are fine, I just wanted to get u a cheaper z590 board that wasnt micro atx
Gaming PC:
