facetime When I make facetime calls trough my home wifi, my internet connection stops working. How to fix it help please.
Solved by Falcon1986,
17 hours ago, kaans42 said:i checked it and yes it has QoS on and my PC bridge is on high priority
Hopefully, you've set the download and upload parameters to suit your connection speed. Don't exceed your actual limits; doing so adds nothing and can even worsen your experience.
The following are some other things to try after using the Archer C6 emulator:
- When you're using FT, is any other device using the network simultaneously? (e.g. Downloading files over P2P, carrying out online meetings, updating Windows, etc.) 8Mbps upload will get saturated quite easily and tank download speed for all network clients.
- If you don't require IPv6, disable it in the router under 'Advanced' > 'IPv6'.
- Under 'Advanced' > 'System Tools', is "NAT Boost" enabled? If it is, try disabling it and restarting the router. NAT acceleration is more beneficial at higher speeds than what you have and can cause issues on slower connections.
- If uPnP isn't enabled under 'Advanced' > 'NAT Forwarding', you might need to open ports for FT to work properly. Personally, I've never had to do this, but you can try it if all else fails to help.
- If you're using WiFi, enable MU-MIMO under 'Advanced' > 'Wireless' > 'MU-MIMO'. Also, ensure you're using WPA2-PSK security and AES encryption. WiFi optimization after doing a wireless survey can be done at another time if your current issues are affecting wired clients.
Share
Followers
2
