So I’m having trouble overclocking my i9900k. I used the asus intell extreme tuning utility but I fee it’s just customizing the turbo boost not actually overclocking it. Also did it in bios using asus direct video but I think they did the same thing just tuned the boost. Benchmarks suck and running it in the tuning utility says 4.8 max and I have it set to 50 multiplier won’t let me go higher. So anyone familiar with bios setting to overclocking on an asus hero Maximus?  Was super easy to get my flu dialed in but a little apprehensive to actually start messing with bios too much without a little direction. Would really appreciate some help.
https://linustechtips.com/topic/1324587-overclocking-i9900k-please-help/
As far as I know changing the muliplier overclocks it so if it can't get past 50 then that might just be the limit to the overclocking set by intel. U said that the Benchmarks suck so do u mean that they are not quite as good as an overclocked 9900k should be or do u mean that it is worse than what u would expect even an unclocked 9900k to be? If u did overclock it correctly and are getting scores that might even be below the average unclocked 9900k score then I would think that your CPU might be getting too hot and therefore thermal throttling. What cooler are u using for ur CPU? Also, in case u are right and weren't able to overclock, what motherboad do u have as only mobos with top tier chipsets are allowed to overclock?
z370 or z390 hero? if it's z370 rip
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Asus hero Maximus z390 chipset...so I followed asus guide on overclocking then tried Linus video and couldn’t boot....so went back to stock I clock and my benchmarks went up by 20 percent. So once I “over locked” my scores got worse then improved once cleared cmos.
I have a Corsair water cooler never get above 50 maybe maybe 60 so don’t think it’s a thermal issue
