I am trying to OC my cpu. I used to run it at 1.025V 4ghz, I managed to get 4.4ghz at 1.2V and only like a 5 degree temp difference, but I am getting lower scores on cinebench for some reason. anybody know why? how to fix this?
I have cooler master 212 black, asus x570p, and 3600 cl16 memory, 800W psu, 2070 super.
https://linustechtips.com/topic/1324083-amd-r5-3600-oc-help/
did you set this overclock in bios? or in some software.
but you need to raise your voltage, no way a 3600 runs well at 4.4ghz 1.2v
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1324083-amd-r5-3600-oc-help/#findComment-14629615
I set it in bios and tested it first in ryzen master it performs worse in bios
https://linustechtips.com/topic/1324083-amd-r5-3600-oc-help/#findComment-14641623
try raising your voltage to like 1.3v
AMD blackout rig
https://linustechtips.com/topic/1324083-amd-r5-3600-oc-help/#findComment-14641628
