I just bought 2 8gig chips for my computer i have 16 gigs alrdy installed via 4x4 gig chips. When i went and installed the 8 gig chips in place of 2 of the 4 gig chips the computer did not boot. the lights on the mouse and keyboard did not light up screen stayed black. I tried to install just one 8 gig chip and to no luck still black screen tried in all 4 slots. so i put in one 4 gig chip and the damn thing booted so i installed the remaining 4 gig chips that i alrdy had before. my question is why can i not use the new 8 gig chips. they are the same brand and speed just more per chip .
System Information
Time of this report: 4/8/2021, 16:32:58
Machine name: DESKTOP-TSI7VF7
Machine Id: {0F4A0984-08D1-4A1B-B208-51D2433BE026}
Operating System: Windows 10 Pro 64-bit (10.0, Build 19042) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: Micro-Star International Co., Ltd.
System Model: MS-7B85
BIOS: BIOS Date: 08/06/18 14:12:56 Ver: V1.10 (type: BIOS)
Processor: AMD Ryzen 7 2700X Eight-Core Processor (16 CPUs), ~3.7GHz
Memory: 16384MB RAM
Available OS Memory: 16334MB RAM
Page File: 5693MB used, 13072MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.0546 64bit Unicode
https://linustechtips.com/topic/1323988-memory-problems/
<-- moved to CPUs, Motherboards, and Memory -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14628903
Sometimes you might have to clear the CMOS when changing memory configs.
I'd suggest you try that.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14628904
1 minute ago, EarthRock said:
Do i just restart and load bios and look for a clear button or something of that nature?
There should be a battery I your motherboard.
Turn off the powersupply using the switch, then remove that battery and put the new sticking back in 20 minutes later. It has to be at least 20 minutes, PC's can hold enough charge to keep the CMOS powered for a bit.
Bios database
prior build:
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14628925
Okay so turn off the PSU with Switch unplug the PSU remove the battery wait 20 mins install the 2 8 gig chips and 2 4 gig chips and then turn it on. Got it thank you very much
Yes. Remember to put the battery back in facing the right way.
If I remember correctly your motherboard has the 2 sticks ram placement as:
cpu -- empty -- ram -- empty -- ram, it's important to install them this way so you get the maximum out of your perfromance
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14628965
Idk the latencies of the two sets of ram, so even though they are from the same brand and with the same Mhz, I would be careful with mixing them. Having two different chips with different timings will force the faster chip to run in slower mode, so it wouldn't really change a thing cause your 2x8gb paired with 2x4gb could potentially just run as the same config that you had before.
I would try putting the 2x8gb set in this position: cpu ----- empty slot ---- ram ---- empty slot ----- ram
after that (and if the latencies match) you can consider maxing out the slots
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14629007
It shouldn't be a problem, you'll just have to deal with the fact that the faster ram will run at the lower timing and that it wouldn't be a dual channel setup anymore, which would result in "slower" performance. You also have a ryzen 7 2700x, which can take up to 128gb of ram (theoretically), but they would have to be at a max 2900-3000 Mhz speed. Keep in mind that higher gb ram doesn't mean faster performance, if your CPU can't keep up with it. Maxing out all the slots with this kind of setup (i.e 4gb - 8 gb - 4gb - 8gb) would result in a 16/18 gb? ram, but it would be slower than just 2x8gb of ram in dual channel. You can try it if you want, but I wouldn't go furthest than 2x8gb set in dual channel or maybe a 2x16gb 3000Mhz in dual channel with a Ryzen 7 2700X.
You can obv try if you want and test the speed, building PCs is fun because you can experiment as much as you want 🙂
It's not impossible to have all the slots maxed out and make them run at a higher speed, but that would mean overclocking your cpu and amping up the voltage A LOT, which could result in permament damage on your mobo, if you've never done it before. It's really not worth it and in most cases 16gb are more than enough.
Let me know how it goes, let's hope after the cmos is cleared out you can have it run with the 16gb of ram 🙂
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14629046
With that i will just install the 2 8 gig chips i dont want to overclock anything. going to remove the PSU cord and switch it off now and see what happens. Hopefully it just works and i dont mess anything up further lol thanks for all the input has made this mad easy.
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14629054
No big deal! Fingers crossed
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14629056
59 minutes ago, EarthRock said:
the timing is not the same tho.....
4 gig are
  • DDR4 3000 (PC4 24000)
  • Timing 16-18-18-36
  • CAS Latency 16
  • Voltage 1.35V
    8 gigs are
  • Timing 16-16-16-36
  • CAS Latency 16
  • Voltage 1.35V
But the timings are NOT the same
If you are trying to use both 8GB x2 + 4GB x2, make sure, when you load XMP, it is using the 16-18-18-36 timings. The slower of the two.
As for WHERE the sticks should be installed, alternating slots
[--- CPU SOCKET ---] [-- Slot 1 --] [--Slot 2 --] [--Slot 3 --] [--Slot 4 --]
[--- CPU SOCKET ---] [-- 8GB --] [-- 4GB --] [-- 8GB --] [-- 4GB --]
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14629133
4 minutes ago, EarthRock said:
Okay installed everything worked great have a question tho.... in my bio it says it's only running at 2133 but the sticks are 3000 would you know what happened there?
OC menu, and find X.M.P. Profile.
Enabled it, and you should have a new drop-down menu come up.
Select...something like Profile #1 (or #2) DDR4-3000 16-18-18-18-36 1.35V
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1323988-memory-problems/#findComment-14629136
