10 minutes ago, elf dude said:
Budget (including currency):  around 2300 usd
Country:  united Staes
Games, programs or workloads that it will be used for:  gaming and school
part list
https://pcpartpicker.com/list/xmV7Jf
Get 2x8GB ram, use a NVME SSD, the speeds can be up to 10 times faster. Higher end air cooler would be better because the 3700x can heat up under load, such as the be quiet! dark rock 4 pro, dark rock 4, or dark rock slim. Much higher quality air coolers that can keep temps low. For the 3080, it has power spikes that can add up to a total system draw of 1000 watts. I'd recommend a bare minimum of 850 watts, though 1000 watts would be ideal.
Also, kinguin.com has windows 10 keys for under $40, and they arent scams; i got mine from there.
Gaming PC:
CPU- Intel Core i5-10400 (planning to upgrade when Alder Lake releases)
CPU Cooler- be quiet! Dark Rock Slim up to 180W TDP
Motherboard- Asus ROG Strix B460-h Gaming
Memory- Corsair Dominator Platinum DDR4-3000 CL15 memory
Storage- Crucial P2 1TB M.2-NVME SSD up to 2400 MB/s
Video Card- MSI Ventus 2x Geforce RTX 3060 Ti OC
PC Chassis- Cooler Master TD500 MESH ARGB with Controller
Power Supply- EVGA 650w P2 (planning to upgrade to EVGA 80+ Gold 1k watts)
Rear Fan- Touchaqua Bitspower Notos RGB fan
Monitor- Acer EI272UR 2560x1440 144hz 4ms Radeon Freesync monitor
Keyboard- Logitech G810 Orion Spectrum
Mouse- Logitech G203 Lightsync (planning to upgrade to g502 HERO)
Controller- Xbox One Wireless Controller - Red
LaptopProcessor- Ryzen 7 4700U (8c/8t up to 4.1Ghz) with Radeon graphics, 16GB DDR4-3200 memory, 512 NVME SSD
Don't get a 3080 for 1080p. You can't even get full utilization out of it, because there's not a CPU that exists that won't bottleneck a 3080 at 1080p.
Get a B550 board. You're going to at least want the option of PCIe 4.0 before you're likely to upgrade.
Get 16GB of RAM.
The 860 SSD is a QLC drive. It's not worth it.
If you do stick with the 3080, you should get a higher wattage PSU. 850W at least. It doesn't generally need all that power but it spikes and you need the higher capacity for stability when it does.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
Some things I'm going to point out
Don't pay that price for the windows key there is much better places like kinguin that will save you some money
Get at least a B550 board that's just more worth it
Try to get 2x8GB sticks 3200mhz at minimum or at best 3600mhz
You could go for a M.2 NVME SSD that's more future proof and faster
That GPU you picked is most likely overkill since looking here your monitor is just 1080p and most modern GPU's can push 240fps easily (you never listed games)
If you do end up going with the 3080 get a  850W PSU at minimum
Why 2 different brand fans? looks like 2 of the cooler master would save you money
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
