SQL Best Practice On Joining Tables ?
For MySQL I can't tell if it's that critical as I use it rarely as I need much faster and robust database. But for example on MSSQL a where clause can be read prior of executing anything which allow MSSQL to use prediction to find records much faster. When the condition is embed in the join it need to filter per Row on the RowStore making it filtering many many times. When dealing with low record count it is a non issue but when joining billions of records with another billions of records there is a huge performance impact.
BUT filter in the join can apply the filter right away and leave more space in the RAM while applying the filter on the where clause force larger chunk to be loaded at a time which cause more RAM to be used. Filter is still applied on the result set row by row but you do have a complete set of fields that may contain nulls which are way heavier in memory than for example a simple bit that was filtered. If you have bad table designs you can more than double the RAM of what the query result actually contains when using where clause.
So if you are RAM limited try to put as much conditions within the join itself. You will have a smaller RAM footprint hence allowing more user queries to pass but they are slower.
If RAM is not an issue, use the WHERE clause to filter which will make the query faster but take bigger RAM footprint.
Now this is just a general guideline which doesn't mean it's a cure for all solution. Each query, each server, each database software are different. At the end of the day you should test your query against an evaluator like a query plan or query statistic and try real life scenario and adapt the query for REAL use case. For example on MSSQL if you test you query back to back it will get everything loaded into RAM tables and suddently a 20 second query will go down to 2 seconds as it doesn't use the table on disk but the one running in the RAM which is much faster. That 2 seconds wouldn't be a good value to assume if you query is ran once every hour but it is if it's ran once every 5 seconds.
