Hi! I have a quite old celeron system, and i want to throw the celeron away. The system contains a 2.4 ghz celeron processor in it. I want to buy a pentium 4, exactly this: # of Cores: 1 # of Threads: 2 Processor Base Frequency: 3.00 GHzCache: 1 MB L2 Cache Bus Speed: 800 MHz Socket: PPGA478. The MB is an Asus P4V8X-X, wich supports hyperthreading, and as I found at "overclocking mode" 800mhz front side bus too. It also writes that it supports prescott core processors, but i currently run a northwood, so idk anymore, anyone? Will it work? (note: Im younger than the motherboard)
https://linustechtips.com/topic/1322686-pentium-4-help/
What model number exactly? Would be more useful.
F@H
GPD Win 2
https://linustechtips.com/topic/1322686-pentium-4-help/#findComment-14620057
This page will help you to find a CPU to fit the list; if you enter your criteria into this page, you can find a list of Intel CPU's that meet the criteria.
EDIT:
P4 - 530, 540 & 550 would fit the bill.
Edited by Eighjan
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1322686-pentium-4-help/#findComment-14620093
Thanks for replying! After a little research (the seller didn't write it out, cause why would he) it's spec number is SL7P, which means this is a P4 530, as I found out. https://ark.intel.com/content/www/us/en/ark/products/27463/intel-pentium-4-processor-530-530j-supporting-ht-technology-1m-cache-3-00-ghz-800-mhz-fsb.html
And because the processor is listed for about 3 dollars, it  definitely worth a try.
https://linustechtips.com/topic/1322686-pentium-4-help/#findComment-14621515
This CPU isn't on the mobo compatibility list and the manual says it only officially supports 533MHz FSB CPUs, but can do 800 through overclocking... so might work or not, maybe only with an underclock. Anyway, for $3 probably there's not much to lose.
F@H
GPD Win 2
https://linustechtips.com/topic/1322686-pentium-4-help/#findComment-14621680
Ye, i checked and didnt found on the list but it's support cpu with the same specs but higher clockspeed, so i'll try it, not a big deal. I also have 2 other 478 boards, one will probably support it. Thanks for answering!
https://linustechtips.com/topic/1322686-pentium-4-help/#findComment-14621808
4 hours ago, csinti said:
And it works, thanks. But can you recommend me a program, which can change the fan speeds, and work for XP?
SpeedFan should still work on XP
Intel Core i9-9980XE 18c/36t, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Palit RTX 5070, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, Meshify 2
PC 2: AMD Ryzen 7 3700X 8c/16t, MSI X470 Carbon, 32GB DDR4 2666MHz, Asus GTX 1080 Strix, 512GB Samsung PM981, 1TB Crucial MX500, Fractal Define R4
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 48GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 3: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Phone: Samsung Galaxy S23 256GB Watch: Samsung Galaxy Watch7 44mm LTE
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
Z77: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 32GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
https://linustechtips.com/topic/1322686-pentium-4-help/#findComment-14632339
