Budget (including currency): £600ish
Country: UK
Games, programs or workloads that it will be used for: Primarily Flight simulator
So a friend has hit me up asking about a PC for his girlfriends dad. He basically just said he wants it to play flight simulator on it. Ive been abit out of the loop recently with components so not sure on what to recomned to him.
All he needs is the tower i can sort windows for him and he has all the other stuff.
Any help would be grand
https://linustechtips.com/topic/1322115-flight-simulator-build/
for 600 and if we are considering gpus at MSRP, he's not gonna run flight simulator 2020 not even on ultra settings or high, is he fine with it or?
depending on the components inside, most likely low settings is the best he can get, Medium if in some cases.
Unless the flight simulators he plays are older for ultra (from 2018 or lower I think, maybe medium-high for 2019 ones)
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
https://linustechtips.com/topic/1322115-flight-simulator-build/#findComment-14615557
Country: UK
The graphics card market it so out of stock that it is probably worth it getting a prebuilt.
https://linustechtips.com/topic/1322115-flight-simulator-build/#findComment-14615562
You would have to get a prebuilt for this, and even then flightsim would be restricted to 720 low to get stable 30fps
(I have a rx480, that’s the max I can do)
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1322115-flight-simulator-build/#findComment-14615626
RX 580/GTX 1060 could prob do 1080p Ultra at 30+ fps. I ran my temporary RX 580 at 1440p high and managed 25 fps. Not great, but not bad.
I'd wait a bit though for stock to come in and old parts to fall in price.
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
https://linustechtips.com/topic/1322115-flight-simulator-build/#findComment-14615641
