I don't know why but my modmic no longer shows up in windows. Has anyone had this problem and fixed it? I have a modmic usb.
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/1321757-help-my-modmic-stopped-working/
Try it on a different device?
If it doesn't work there, I think an RMA may be in order
It does work on other devices. As far as I can tell its a windows problem or mabey an amd usb problem? It will work if I mess around alot but then eventually breaks again.... Ill try it on another device for longer soon
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
You running ryzen?
