Best Liquid Cooler & Fans For AMD 5950X?
TheOnlyUser
I am about to get AMD Ryzen 9 5950X but having a hard time choosing the Best Triple / Dual Fan Liquid Cooler.
I am planning to get Lian Li PC-O11 Dynamic
I want my PC to look something like this
Pic 01, Pic 02, Pic 03, Pic 04, Pic 05
I want other fans too, which I can place on the cabinet my tempered glass.
Look for around $150-$300 price range for all cooling components.
Let me know If more information is required.
Thank You
i assume you want RGB so ekwb aio is a good choice i think, their fan also look cool
AIO: https://pcpartpicker.com/product/yLBhP6/ek-ek-aio-360-d-rgb-6604-cfm-liquid-cpu-cooler-ek-aio-360-d-rgb
240: https://pcpartpicker.com/product/svkgXL/ek-ek-aio-240-d-rgb-6604-cfm-liquid-cpu-cooler-ek-aio-240-d-rgb
Fan: https://pcpartpicker.com/product/RFvqqs/ek-vardar-evo-120er-77-cfm-120-mm-fan-3831109824641
140: https://pcpartpicker.com/product/6QXYcf/ek-ek-vardar-evo-140er-84-cfm-140-mm-fan-3830046995469
I'll give you an interesting option, the Swiftech Drive X3 https://www.swiftech.com/drive-x3-aio.aspx. I have the 280mm H240-X from Swiftech that I used to cool my FX 8350 when I got it in 2014, and they made a TR4/AM4 bracket later on so I am still using the same cooler now with my 5600X. Swapped out the fans for Noctua 3000RPM Industrial PPC ones although the Swiftech fans were great.
These are essentially custom loop starter kits since they are fully expandable, and are wayyy cheaper than a custom loop, plus you're getting copper/brass radiators over the cheap aluminum ones found on sealed AIOs.
Thank You
I would say a 360mm is the way to go. A corsair iCue h150i Capellix would be great.
ek aio
artic liquid freezer ii
phanteks glacier one mp
are going to be the best options
the swiftech water loops are pretty nice but hard to get ahold of.
if you want something like that I would consider alphacool instead. plus alphacool aio are all copper which is nice.
