Hey guys,
I hope someone sees this :)
So today my pc just shut down and doesn't turn on again. So naturally I took it out of the case and built it outside. I tried to boot again, but still nothing. At first I thought it was the PSU but I jump-started it and it was fine. Then I got the idea to jump-start it while the 24pin was plugged in, I thought maybe it's like jumpstarting a car. Anways, the cpu fan started spinning at max speed, so I took it off to see if the cpu is overheating. It was ice cold, which makes me think that it's not getting any power. But the chipset heatsink was literally like 1000000 degrees. I really don't know want to do at this point. I think that the chipset is the problem. The Gigabyte support needs like 3-7 days to contact me back so I hope someone here knows how to fix this  :)
I also tried taking ram out, gpu too.
components:
i7 6700T
Gigabyte H110M-S2H
XFX RX 570 8GB
16 GB G.Skill Aegis
https://linustechtips.com/topic/1320496-cpu-cold-chooser-hot/
EPS cable (or the CPU cable, same thing) is plugged in at all times right?
Desktop benching:
https://linustechtips.com/topic/1320496-cpu-cold-chooser-hot/#findComment-14602674
If a system shuts down out of nowhere it's usually because of one of two things. Either the PSU has a problem or something overheated. Usually the latter.
https://linustechtips.com/topic/1320496-cpu-cold-chooser-hot/#findComment-14602684
