Hi. I have a AOC C27G2U monitor, and yesterday my Microphone stand unfortunately flew into the panel, and smashed the Monitor. While looking for new ones, I remembered the LTT video where they repaired an AORUS monitor by just swapping out the Panel. I'm still trying to find the Panel, but it's a massive Headache, and I don't want to open it, look up the sticker, and close it as im afraid I might break something else by opening it twice (Shit happens, people!). I've checked a lot, but Display Ninja didn't list the Panel, and Panelook.com had way too many ones with about the same specs. So I've resorted to asking the LTT forum if you guys have any idea.
https://www.digitec.ch/de/s1/product/aoc-c27g2ubk-27-1920-x-1080-pixels-monitor-13974576
https://www.panelook.com/modelsearch.php?op=advancedsearch&order=panel_id&application=41&inch_low=2700&inch_high=2700&form_factor=20&resolution_pixels=8180&ppi_low=80&ppi_high=90&touch_screen_main=No&vertical_frequency=165&display_mode_lc_family=2&surface_glare=AG&brightness_high=2503&color_gamut_system=srgb_coverage&sunlight_readable=-1
-BSG
https://linustechtips.com/topic/1320112-help-with-finding-panel-urgent/
Open it up and look for a panel part number. It's not like you can still use it anyway. If you're scared of opening it twice just leave it until the replacement arrives.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
