What?
So it doesn't start after cleaning it with qtips, I got that.
But did you disassemble it when you cleaned it? What do you meant it doesn't start? No video? No fans? Any error code or debug light on the motherboard?
Specs?
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14595844
Just now, VronInfinite said:
Dude I can't see what the light has written next to it. Could you at least take off the side panel?
Bios database
prior build:
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14595863
It says EZ debug LED
I know that, but there's text next to each light. It details whats wrong. (There would be CPU, vga, ram and boot)
Bios database
prior build:
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14595867
And, only the CPU lights up when i turn it on
Ok. I need you to unplug the cable from the top left of the motherboard. It's the 8 (or 4) pin EPS and probably will be a b*tch to unplug.
The plug it back in.
Bios database
prior build:
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14595888
Still lights up and no connection
Ok. You did plug the EPS back in right?
Then I'd need you to take off the cooler and take out the CPU. Then put the CPU back in and the cooler back on. (And if you have some thermal paste,clean it off the CPU and cooler and put some new paste on)
Bios database
prior build:
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14595916
Nvm still not working
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14595927
So is my CPU Broken?
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14595979
Unlikely.
Try clearing CMOS  (Unplug pc, remove battery for 20 minutes)
Also did you put new thermal paste on the cpu?
-Scott Manley, 2021
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14596001
5 hours ago, VronInfinite said:
did you unplug the ps u from the wall?
Bios database
prior build:
https://linustechtips.com/topic/1319670-help-pc-wont-start/#findComment-14596419
