Nvidia 650ti Aftermarket cooler
Solved by the pokemon kid,
There must of been something wrong with the stock cooler.
I have just installed the Arctic Mono plus! Very easy installation and also comes pre-applied with thermal paste. The cooler does sit about an inch and half taller than the card now but overall I am not that worried. It has easily halfed the noise output compared to the stock heatsink which is perfect! Also the temps have gone from 48°C Idle to 18°C Idle! Which makes me think that there was something wrong with the stock heatsink.
None the less a big +1 to the Arctic Mono Plus as a aftermarket cooler for the 650TI!
