Help installing gt 710
Go to solution Solved by ProjectBox153,
Yes, you'll have to bend them out. You can put a screwdriver into one of the holes and twist the bracket. They're designed to be pretty easy to remove. It's a cheaper alternative to reusable slot covers.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/1319240-help-installing-gt-710/#findComment-14592565
You can bend them till it breaks apart.
It's normal.
https://linustechtips.com/topic/1319240-help-installing-gt-710/#findComment-14592577
thx
https://linustechtips.com/topic/1319240-help-installing-gt-710/#findComment-14592667
 Are we talking about the pci slot covers?   I took them out of my windows vista  pre built no problem and they looked exactly like this?
It's just missing those other covers because one is for the GPU obviously, and the other I thought "at least some airflow"  🤣
-Scott Manley, 2021
https://linustechtips.com/topic/1319240-help-installing-gt-710/#findComment-14592816
